It's probably mostly the case, GHO5T.
So I am going in standard, no coil-overs anymore!
Because it says once I get them engineered.
I'd still need to wait for the statement of requirements to come in..
I've had enough waiting & waiting!
Will SA Regency require my rear coilsprings to be stock as well or I can leave the aftermarket ones in as they don't adjust on the coilspring, but only on the shockie strut threading??!
afaik aslong as they dont adjust and aslong as the height is legal your not gonna have a problem.
I have bolded the bit that would bother me. If you can wind the spring perch up and down the damper body, then you can adjust the height, and Regency will ping you for it. You have to weld such things to prevent them being able to be moved in order to pass inspection.
  • Like 1
can tac weld and break the weld later
i would still be looking to borrow a set for the pits trip though.
when you duck around the rules they tend to look for something else. my belief is to put the effort to do the right thing and they stop looking for something else to hold it back.
Edited by GH05T
  • Like 1
Yes I am getting a set for sure!
Too much risk with coilovers.
How strict are they on tyres?
Every part of the tyre needs to have tread? Or can one tyre on the inside have a low spot?
Can I go 18's with new tyres or stay with stock 17's for inspection for now?
  • 3 weeks later...
That was a great $700 investment for used stock suspension, lol.
SA Regency Inspection failed me on Friday even with the stock suspension installed because it was used & not in near new condition.
Which resulted in it sitting 9mm lower than normal! :(
What was the actual problem there? Was it that it was "used and not in near new condition"**, or was it that it was "9mm lower than"***? See the expanded comments below before answering that.
** You see, I refuse to believe that they would defect (or refuse to pass) a car that had used suspension on it unless it was obviously bad in some way. Perished rubber parts (like spring isolators) or oil leaks would definitely attract their unhappy face. But my car went over the pits there a couple of years ago with suspension that had been on it for nearly 15 years. One of the rear dampers was actually leaking, but a clean off of oil and replacement with general grime (clean rag followed by grimy rag) was all that was required to get over that the day before the inspection. Note I replaced those dampers shortly afterwards, so I wasn't really trying to scam the inspection. Nevertheless, it proves that even quite "old" suspension parts is not going to cause you to be failed.
*** Here's the real question. Is "9mm lower than normal" to be taken to mean "9mm lower than standard" or is it meant to mean "9mm lower than the minimum acceptable height"? Because, again, when my car went over it measured almost EXACTLY to the lowest allowable height (like within a mm at each end - over the minimum of course) and so was passed. But this is like 15mm (or perhaps even more) lower than stock.
  • Like 1
So you went to all the trouble of putting in stock suspension and never checked for yourself that it met the minimum eyebrow measurement?
A spacer would have solved your issue.
They didn't fail you because the suspension was used! It was too low.
  • Like 1
Well that'd be handy Ben, but I didn't have the specs & no one passed on the eye brow height measurements to me!!!
Lowest allowable is 360mm...
The Brisbane SAU Member sold me 350Z Suspension, not the 370GT Suspension as we agreed on...
Hope PayPal can fix him up a little bit!!!
Anyway I failed the Full Roadworthy last Friday morning on the Middle Seat Child Restraint Bolt not being present (BOSE Sound System is in the way).
Tint was too dark at the front (even though I asked for darkest legal tint, work that out)!!!
Rear ride height is sitting too low (9mm) from minimum allowable.
HID bulbs (which was the only thing I was afraid of failing on)!!!
And to top it off the Import Factory in SA hasn't got my Model Coil Springs!!! :(
So I can't do nothing to pass SA anymore...
ok, i dont mean to rag on you or anything but
- rookie mistake but that gets allot of people - easy to fix
seriously... you went through with tint.. why would you even?
-stock stock STOCK STOCK STOCK STOCK
- and....you......you didnt remove them..........................
- appart from fix the obvious issues of why you failed?
remove front tint
use STOCK springs STOCK MAN!
remove hids
install child anchors
do this then go pass?
Too bad, no ones got stock 350GT Spings Glyn.
I thought Import Factory SA would have them, but nah!!!
HID's (Auto Elec: $250) Total for re-wiring twice?
Tint ($150 Approx?)
Restraint Bracket Fabricated & Bolt ($200 Approx?)
And the same place that done my mums front side windows tint looks fine, not as dark as mine!
but why would you go to get inspected with lowered springs. its not like we just had a whole topic discussing it.
HID cost to remove and refit..... well.. yes ..... unless im totally lost here and you DO want to get your car passed?
tint, just never go with tint on the front windows. you cannot do it.. its clearly in the rules.
the bolt (afaik) is factory, find one and bolt it in. if you have to remove your speakers to do so then remove them.
like i said im not the expert and im not trying to have a dig, but going to get inspected with lowered springs tint and hids after starting a thread about getting a car passed on a forum with a bazillion threads about these things i struggle to feel sympathy.
How am I meant to know 350Z Suspension sat lower when the seller said they were going to be the same as the 350GT? Hello...
That's the big issue here that I am pi**ed off about, 'False Advertising'!!!
And the middle rear child restraint is 'missing'.
Needs fabricating a bracket attached from both sides of the bolts if that makes sense.
Why should I spend another grand doing all this and risking future HID wiring issues.
When I can get it rego'd in another state for the same price with HID's still intact.
Defeats the purpose now.
Have tried twice now, I would of got pinged for the middle child restraint first time as no one warmed me!
My car is all safe (besides front tint), SA Gov is over doing it completely!
That's why not many used cars in Adelaide are for sale unregistered...
Registered or not in SA makes no difference when selling.
It's only when transferring rego from another state
The fact is your car snuck through without meeting the proper ADR requirements. That's not SA's fault.
  • Like 1
totally understood
it does, take it to a shop that fits them, maby www.willshire.com.au
to get it regoed.
cannot, its an ADR rule, australia wide and is done on all imports, just part of importing a jap car unfortunately.
you can try as many times as you like, fortunately now you know exactly what is needed to get this done finally. luckelly its simple bolt on bits, could be oh so much worse.
simple things by the sounds of it. i understand some things are a bit shit but none of this is new to anyone with an import unfortunately.
sa is not the worst, trust me. but yes.
almost there mate. just address the issues, deep breath and enjoy the car.
then mod it and get defected like the rest of us :)
Posted Today, 02:21 PM
Edited by GH05T
  • Like 1
The rules and the guys in SA are not bastardy at all. The guys at Regency are strict, but generally very fair. When people turn up with the wrong attitude they will get a harder time of it. If the same person turns up regularly (with defects), they will get a harder time. But these things are entirely under the control of the person turning up.
My car got passed with a number of small things that they could have pinged me for. Was done on the proviso that I clean them up as soon as I could. Some of these I did, in good faith. Some of them I ignored because it suited me to do so. But the point is that the guy I dealt with treated me very fairly because of the state of the car I presented and my attitude when I did so. Those guys at Regency aren't pricks who want to ruin everyone's lives. They are all car guys, that's why they are there. They also know that it is very very possible to have a car, including a modified one, that meets the rules. The rules are fairly strictly enforced in SA (despite the slackness of not having regular roadworthies and so on), but at least they don't have a whole bunch of really stupid rules like they do in Victoria.
In fact, in SA it is possible to get really spastically modified cars approved, so long as you work closely with the Regency guys during the planning, engineering and build. You'd be surprised what is legally, and I mean truly legally, driving around in Adelaide.
  • Like 1
Totally agree that it is very important on what attitude you give your inspector!
He commented 'besides these faults, it's a neat car'.
Which was cool to hear from them :)
Vehicle Standards never replied to my 2 E-Mails I sent them about my specific procedure!!!
Then I gave up & just went in without knowing the known requirements...
Statement of Requirements on first go for the 'missing import approval sticker'.
Got that sorted, then the 4 faults on the 2nd visit.
What are the strict VIC rules that you hate & others?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
