Build engine with standard rods and aftermarket Pistons if that's what you want to do. But be sure to abuse it (and video it) and post back with results(and videos) :)
+1 on video
can't wait to see the photo of this carnage, don't do a half ask job too. i want to see a massive hole in the block :)
I know of a car that ran about 400kw with standard rods for 10 years before they failed. When they failed the ripped in half. But it lasted a long time. I went with brand new rods on my build (nitto's) because they were cheap enough while the engine was apart.
+1 on video
What do you seriously think would cause that to happen with 450kw and prepped standard rods?
Age. It will eventually get any reciprocating part. Prepping standard rods buys you a certain amount of extra strength, and depending on how much effort is put into looking for cracks and so on, a certain amount of confidence that they are in good condition and not harbouring any cracks. But new cracks can form at any time once they've been up and down enough times.
The other killer is of course, rod bolts and the usual risks of being assembled incorrectly.
I have seen a few built blocks split their bore at not much more than 450kw, personally I would be keeping it as close to stock sized pistons as possible so as not to weaken the bore.
It's not pretty snapping or bending rods, I have been engulfed in the oil fueled fireball whilst standing beside the dyno, I would hate to see the carnage if it happened on the road at full noise for the sake of a relatively cheap set of rods, especially as you have the engine apart...
Why bother at all, just see what you can get out of the stock internals.
It was a late model 1UZ, light rods known to be undersized for the 1200nm of torque it was putting out. Ethanol was the culprit, along with the GT35 I fitted to it.
The RB26 block split was due to cylinder pressure I imagine, as was the Cossie Sierra race block that did the same thing. Tuning past that imaginary point where pressure beats steel. :P
  • Like 1
Ethanol produces more torque compared to petrol for similar power, especially when you lean on the boost past where the power stops rising. It is also nearly impossible to find the point where cylinder pressure rises exponentially due to it's anti detonation qualities. At some point some part will let go, where that is who knows, it comes down to your tuner at the end of the day.
If the 1UZ was on petrol, due to being high comp we would have had to stop boosting well before the point the rod went, with less timing. Revs were kept pretty much stock as I remember.
Just throw a stock rod under a 100lt press and record the pressure it starts to bend at, then do the same for an h beam/forged rod.
Bam...
Stock rod strength question answered!
15deg axial load, I'm going to say..... 3t
J.
Bam...
J.
Thats actually quite genius! anyone willing to donate a H beam? lol i got heaaap of spare rods
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
