Hi Guys,
Been reading through the M35 Exhaust threads but it all seems to revolve around the ready made catback systems.
What I want to achieve is a twin exhaust, similar to the image in the link below but just from catback instead of full system due to budget.
http://www.zees.co.jp/story/img/stagea_35/veldiss_09.jpg
My issue is that there is stuff in the way on the RH side and I don't know what it is, what is does and if it can be moved?
Can anyone help?
Thanks
Edited by NZnismo
https://www.sau.com.au/forums/topic/454935-m35-how-do-i-run-a-dual-exhaust/
That Zees exhaust is on a series 2 M35 which do not have the ATTESSA pump on the driver side rear like the series 1 M35's have.
You could probably do it without a muffler I guess - hard to remember how much space the pump takes up.
Damn, it had to be something important like that... It takes up a fair bit of space, I'd say almost 2/3 the size of a muffler?
Any chance of relocating it somewhere else? Suppose it would be too much hard work just to put a muffler in its place.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
