Hi Guys,
Been reading through the M35 Exhaust threads but it all seems to revolve around the ready made catback systems.
What I want to achieve is a twin exhaust, similar to the image in the link below but just from catback instead of full system due to budget.
http://www.zees.co.jp/story/img/stagea_35/veldiss_09.jpg
My issue is that there is stuff in the way on the RH side and I don't know what it is, what is does and if it can be moved?
Can anyone help?
Thanks
Edited by NZnismo
https://www.sau.com.au/forums/topic/454935-m35-how-do-i-run-a-dual-exhaust/
That Zees exhaust is on a series 2 M35 which do not have the ATTESSA pump on the driver side rear like the series 1 M35's have.
You could probably do it without a muffler I guess - hard to remember how much space the pump takes up.
Damn, it had to be something important like that... It takes up a fair bit of space, I'd say almost 2/3 the size of a muffler?
Any chance of relocating it somewhere else? Suppose it would be too much hard work just to put a muffler in its place.
