For sale is my freshly refurbished trust/ quafie Dogbox.
This is a 6 speed straight cut gearset in a stock Gtr casing. H pattern manual. You will need to supply your own transfer case and shifter.
Many people have held big power with these gearboxes and they are a great option if you keep blowing stock boxes. The gearset can be taken out of the casing and installed into a rb25 casing if you wish to run it for a rwd setup.
I am only selling this gearbox because I am purchasing a hollinger.
Please call or sms me on 0422216160 if you have any further questions.
No payment plans, no PayPal. Just cash in hand or bank transfer if i have to send interstate.
$6,500 - slightly negotiable.
  • Like 1
Dogbox also has the billet sandwich plate made by greddy (grex)
Ratios;
1st: 2.782
2nd: 1.938
3rd: 1.506
4th: 1.178
5th: 0.918
6th: 0.777
rev: 3.28
make a offer guys... parts are easy to get for these dogboxes. quafie still makes everything for them.
  • 10 months later...
I didn't find the box to stupidly loud to be honest. But I think we all have different variations of loud lol.
Yes it can be used on the street quite easily.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
