yeah sorry, not trying to alarm just inform.
also the other issue for excessively rich tune on a new motor is fuel gets past the unbedded rings and into the oil...and petrol is terrible for bearings.
I know.
Every time I fill my tank I spin another set :)
just about back to the original thread topic, my fuel is too rich and then once it is leaned out a bit, will it give a better power result..
I know now that after a short time with new plugs you can feel the car getting more sluggish and it is not long before it wont rev much past 6000rpm without playing up.
needs more WOT.
Lower compression, thought it was the same, maybe a little different with the lager capacity ?
Maybe because I suggested they did not install the starter motor properly after the build. It was OK before then ?
I love it when people say it was OK when we tried it , but the problems are there the first time you drive it out of the shop , farking black magic :merli:
have had many "could not fault" issues.
One in particular.
Hyundai imax.
Stalls randomly.
4 service staff drove the car over 8 days(randomly and myself included).
Didn't happen once.
Customer comes in, drives, stalled.
Still trying to figure it out.
Just very hard as we can't replicate, so don't know if what we have done has worked.
Windsor exhaust did the mid muffler and i did the rear cannon which i made out of a HKS Super Drager
+1 for Windsor exhaust (west Sydney).
Built my 4 inch system, fairly quiet, just the way I wanted.
Fingers crossed this gets sorted soon.
Got everything X ,
All very frustrating , when you think they are putting the right bits in to make everything work and one keeps finding shit that is not up to the job, now the down pipe is too small :(
Paul was saying this exhaust system should never have been built this way in the first place for this build, should have been at least 4" through to the tail.
I think he said he is running twin 3" , that makes mine seem very inadequate for a 3.2 .
Any other suggestions , trouble is I feel like I have spent enough and I know I should bite the bullet and go 4" , any idea what this would cost, The old one cost about $3500 including the down pipe, they just used the old 3" Cat.
Hax near parra (can't remember his shop name) is the best guy for that job pete..
I got my exhaust done for a lot less then that and it's very very good quality steal, workman ship and I dare say there was more labour then yours by the time he did the turbo side and intake too.
Even welded new brackets for my cooler and bored out the compressor outlet of the turbo.
I can tell you I would have had a lot of change left over for 3500!
post-47556-0-77644200-1430220433_thumb.jpgpost-47556-0-59852800-1430220463_thumb.jpgpost-47556-0-60012700-1430220517_thumb.jpgpost-47556-0-93516300-1430220584_thumb.jpg
  • Like 1
What size is that 4"
Here is the final Dyno tune , he said it had back pressure as the 3" exhaust is too small, I said he had a 3.5" fitted but it turns out only from the Cat to the tail and the down pipe was 3"
Edited by Nismo 3.2ish
Yea 4inch to the cat.. 3.5 after.. Your turbo is bigger then mine pete
If I run a 4" to one of those Venom 5" and left the 3.5" exhaust system on , would that work OK ?
You know I am not chasing a zillion HP, just want the farking thing to work
That's exactly what I'd be doing.
Heaps of combinations, but you want to try keep it legal as possible (probably isn't anyway :yes: ) and flow well. So the 4" from the dump is the best as you want bigger there. Then stepping down to 3.5" after the cat is perfect and can muffle some of the noise generated from this beast.
If you didn't have to worry about emissions or noise, which would never happen in the real world, then the perfect idea would be to just route a dump pipe out the side of the car.
  • Like 1
Yea that would work fine I reckon mate
If you do the Math, the area and flow of a 4inch pipe is soooo much greater then 3"
4" is equivalent area to twin 3".
My 4" in mild steel with cat, mufflers and welding the wastegate was 1700.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
