should of bought my head, already had cams in it :no: ,
If I were you id slap the neo head on and add some water meth, would be very ballsy motor plus the cam has 8.5ish lift and zero hydraulic lifters to make noise later.. ;)
Yeah, I was seriously considering it man..
But I really needed the head asap as I can't bear to have my car just sitting there :(
+ Not that I don't trust you, but the head would have come from Brisbane etc.. It could have been damaged coming here and if anything happened I wouldn't be able to just send it right back if you know what I mean?
Unfortunately I have already sold the NEO Head to one of my mates for his R34 but I do regret not keeping it.. I realize now I could have kept the head and just got a thicker Head Gasket to compensate for the higher compression but at the time I did not think of that :verymad:
Oh well, That may be a task for my project motor which will be started soon :yes:
no worries im gonna use it for the RB3025 and see what it does,
nice build, front spoiler looks good!
Yeah, I'm thinking the same thing for my build but I wanna take it one step further ;)
Front spoiler..?
not sure what look you going for but here's a pic of my brothers s1, I'd drop my s2 for it if he would sell it to me...
came loaded with nismo gear from Japan, :verymad: and mine had nothing, sorry pictures not the best..
Edited by AngryRB
That looks nice!
It may be a Nismo 400R? - http://en.wikipedia.org/wiki/Nissan_Skyline_GT-R#NISMO_400R
Also, this.. is my goal (I'm almost there) except with the addition of Wider Rear Fenders + S2 Spoiler :yes:
:yes: :yes: :yes:
I was looking at GTR style ones (no badge of course) but seeing the black on white gives a similar effect while maintaining the S symbol :D
Yeah exactly! I don't know why people switch em out :no:
I personally like em! :yes:
  • Like 1
I want this R33 GTR Do-Luck rear bumper, that's what on my brothers car, it continues underneath the body about a foot or more... gives it more depth at the rear..
http://www.japsalon.com/Frames/00_R33GTR.html
Edited by AngryRB
Not really an update as such
Just something someone did for me and I thought it was cool!
I will be buying ARP Head Studs next week though!
Then all I need is the Head Gasket (Probably a Permaseal Metal Head Gasket) and the Head refurbished :D
Then she's all ready to go on! :w00t:
Keep an eye out as I'll also be documenting the removal and refit of the Head via Youtube :yes:
I will post the links here for all who wish to see it :cheers:
Looking heaps better now... what power you wanting to make?
Can make well over 300kw's with OEM bolts and gaskets... looking forward to the vids... :whistling:
:thanks: mate!
My power goal for this engine is 400rwhp, I really want to see those numbers on the dyno :yes: Then I'll be happy!
Although 1/4 times are what really counts :thumbsup:
Then I am going to leave it at 400hp and a weekender, whilst I start my engine build, RB25/34 :D
Although I am torn between using my current head (The broken one on my car, which will be switched out with the new head) or buying a NEO Head for this, I just don't know whether the slight increase in flow will be worth it with the NEO as opposed to just staying with my head. :ermm:
Update time!
I got my quote from HeadTorque yesterday and although the price seems a bit dear, I am confident this is still a fair price :yes:
They are going to:
- Service The Head
- Pressure Test It
- Sonic Clean And Bleed The Lifters
- Face It
- Supply And Fit Brand New Exhaust Studs
- Supply And Fit 24 Valve Stem Seals
- Check Valve Springs
All for the price of - $1,100 :happy:
But as fate should have it, this will not be getting done till next month! :down:
I am currently casual at my job and have my review next month as I'm waiting to go full time.
I don't want to spend big money now and then be struggling to survive later, should I not get extended :ermm:
I will however still be buying the ARP Head Studs soon, so check back for those updates! :thumbsup:
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
