should of bought my head, already had cams in it :no: ,
If I were you id slap the neo head on and add some water meth, would be very ballsy motor plus the cam has 8.5ish lift and zero hydraulic lifters to make noise later.. ;)
Yeah, I was seriously considering it man..
But I really needed the head asap as I can't bear to have my car just sitting there :(
+ Not that I don't trust you, but the head would have come from Brisbane etc.. It could have been damaged coming here and if anything happened I wouldn't be able to just send it right back if you know what I mean?
Unfortunately I have already sold the NEO Head to one of my mates for his R34 but I do regret not keeping it.. I realize now I could have kept the head and just got a thicker Head Gasket to compensate for the higher compression but at the time I did not think of that :verymad:
Oh well, That may be a task for my project motor which will be started soon :yes:
no worries im gonna use it for the RB3025 and see what it does,
nice build, front spoiler looks good!
Yeah, I'm thinking the same thing for my build but I wanna take it one step further ;)
Front spoiler..?
not sure what look you going for but here's a pic of my brothers s1, I'd drop my s2 for it if he would sell it to me...
came loaded with nismo gear from Japan, :verymad: and mine had nothing, sorry pictures not the best..
Edited by AngryRB
That looks nice!
It may be a Nismo 400R? - http://en.wikipedia.org/wiki/Nissan_Skyline_GT-R#NISMO_400R
Also, this.. is my goal (I'm almost there) except with the addition of Wider Rear Fenders + S2 Spoiler :yes:
:yes: :yes: :yes:
I was looking at GTR style ones (no badge of course) but seeing the black on white gives a similar effect while maintaining the S symbol :D
Yeah exactly! I don't know why people switch em out :no:
I personally like em! :yes:
  • Like 1
I want this R33 GTR Do-Luck rear bumper, that's what on my brothers car, it continues underneath the body about a foot or more... gives it more depth at the rear..
http://www.japsalon.com/Frames/00_R33GTR.html
Edited by AngryRB
Not really an update as such
Just something someone did for me and I thought it was cool!
I will be buying ARP Head Studs next week though!
Then all I need is the Head Gasket (Probably a Permaseal Metal Head Gasket) and the Head refurbished :D
Then she's all ready to go on! :w00t:
Keep an eye out as I'll also be documenting the removal and refit of the Head via Youtube :yes:
I will post the links here for all who wish to see it :cheers:
Looking heaps better now... what power you wanting to make?
Can make well over 300kw's with OEM bolts and gaskets... looking forward to the vids... :whistling:
:thanks: mate!
My power goal for this engine is 400rwhp, I really want to see those numbers on the dyno :yes: Then I'll be happy!
Although 1/4 times are what really counts :thumbsup:
Then I am going to leave it at 400hp and a weekender, whilst I start my engine build, RB25/34 :D
Although I am torn between using my current head (The broken one on my car, which will be switched out with the new head) or buying a NEO Head for this, I just don't know whether the slight increase in flow will be worth it with the NEO as opposed to just staying with my head. :ermm:
Update time!
I got my quote from HeadTorque yesterday and although the price seems a bit dear, I am confident this is still a fair price :yes:
They are going to:
- Service The Head
- Pressure Test It
- Sonic Clean And Bleed The Lifters
- Face It
- Supply And Fit Brand New Exhaust Studs
- Supply And Fit 24 Valve Stem Seals
- Check Valve Springs
All for the price of - $1,100 :happy:
But as fate should have it, this will not be getting done till next month! :down:
I am currently casual at my job and have my review next month as I'm waiting to go full time.
I don't want to spend big money now and then be struggling to survive later, should I not get extended :ermm:
I will however still be buying the ARP Head Studs soon, so check back for those updates! :thumbsup:
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
