R32gtst Parts + 32gtr Bonnet And Plenty More!
Hi all, having a shed clean out. Want to have this stuff gone by the end of the April, if not it's going to scraps!
I'm located SOR in Leeming and would prefer pickup where possible. Otherwise i'm happy to ship or deliver at an additional cost.
Contact: 0405448186 (Prefer sms or call, at a reasonable hour!) otherwise post in the thread.
All parts are from an R32gtst unless stated and all prices are ONO. I am also advertising these parts elsewhere so get in quick!
Cheers
George
HID Kit with full wiring, H3, 6000K - $50 Brand new
post-19334-0-38376000-1428673363_thumb.jpgpost-19334-0-13830000-1428673368_thumb.jpgpost-19334-0-24490500-1428673372_thumb.jpg
R32 GTR Bonnet (little damage from transport) - $150
post-19334-0-84185600-1428673298_thumb.jpgpost-19334-0-28315400-1428673305_thumb.jpgpost-19334-0-58867200-1428673311_thumb.jpgpost-19334-0-11046100-1428673316_thumb.jpg
Aftermarket Grille with mounting points, suites R32 GTST with GTR bonnet or an R32GTR - $70 Brand new
ARC Sidemount intercooler - $100
about 10cm thick (can measure if required) and fits in the standard IC mount point. includes additional pipe to fit stock holes.
Stock intake pipe. - $15
Coilpack cover - $10
6 x Wheels all 5 stud - $150 for the lot, otherwise $75 each matching pair.
2 x R32 gtst wheels - 205/55 R16 (no tread)
2 x S14 wheels - 225/50 R16 (no tread)
2 x Random wheels - 245/45Z R16 ( a little meat left but not much)
Oil Pressure 52mm (i think) gauge - $25 (Brand new)
Oil Temp 52mm (i think) gauge - $25 (Brand new)
DIN gauge panel for 3 gauges - $10 (Brand new)
6 x Stock R32 injectors. Require cleaning & flow testing - $30 for them all, $10 each otherwise
2 x 5mm wheel spacers - $10
Random Jap cup holder - $5
Z442 oil filter, suites RB20 - $15 (Brand new)
Aerospeed adjustable CAM Gears, Brand New! - $50 the pair, $40 each if separated
Stock AFM (i think, the numbers worn off) with mushroom pod - $25
R32 ECU Chipped (i think) - $20
 Share
    • For sure, bromance with common shit box interests.
    • People like Johnny Dose Bro might be laughing at my post because I accidentally added 100mm to my numbers. 350-355 is indeed the lower limit. 450 is off-road Skyline spec.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
    • Aren't we already on one? SAU unforgettable bromance.
    • Easiest way to know is to break out the multimeter and measure it when cold, then measure all the resistances again once it gets hot enough to misfire. Both the original ignitor and the J Replace version. Factory service manual will have the spec for the terminal measurements.
