Racer986jec Posted April 15, 2015 Share Posted April 15, 2015 Where do I start to diagnose this and is there a service manual online anywhere with the codes from the ATTESA Unit in the trunk ? , any advise is appreciated. Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/ Share on other sites More sharing options...
GTSBoy Posted April 15, 2015 Share Posted April 15, 2015 Dunno about the R33 GTR, but the official R32 service manual pdf is on the net in many places. The procedure for entering diagnostic mode is probably the same. I would say though that it is far better to go to a workshop that has a good scan tool and hook that up to the Consult port than trying to get shit computers into diagnostic mode. It's much easier to read codes in plain text than try to interpret the bloody flashes on the dash! Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7516335 Share on other sites More sharing options...
Hadouken Posted April 15, 2015 Share Posted April 15, 2015 The Google manual is Hektik bro http://www.sau.com.au/forums/topic/301753-r33gtr-v-spec-attesa-help/ Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7516337 Share on other sites More sharing options...
XKLABA Posted April 15, 2015 Share Posted April 15, 2015 A bit more info would help When does it come on, ie straight away or after driving for 1/2 hour etc First check fluid in the reservoir in the boot There is a fault code list somewhere that you count the flashing light on the ECU under the pacel shelf Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7516387 Share on other sites More sharing options...
Hadouken Posted April 15, 2015 Share Posted April 15, 2015 Process is detailed in link provided. Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7516435 Share on other sites More sharing options...
Racer986jec Posted April 15, 2015 Author Share Posted April 15, 2015 Dunno about the R33 GTR, but the official R32 service manual pdf is on the net in many places. The procedure for entering diagnostic mode is probably the same. I would say though that it is far better to go to a workshop that has a good scan tool and hook that up to the Consult port than trying to get shit computers into diagnostic mode. It's much easier to read codes in plain text than try to interpret the bloody flashes on the dash! Thanks Im in the US on this one so I will be taking it in for the full timing belt soon but wanted to get some sort of an idea. thank you Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7516523 Share on other sites More sharing options...
Racer986jec Posted April 15, 2015 Author Share Posted April 15, 2015 A bit more info would help When does it come on, ie straight away or after driving for 1/2 hour etc First check fluid in the reservoir in the boot There is a fault code list somewhere that you count the flashing light on the ECU under the pacel shelf Its on when the car is turned on - its at the mark for max fluid thanks - the car has been sitting for like almost 4 years when I got it. Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7516525 Share on other sites More sharing options...
MozzMann Posted April 16, 2015 Share Posted April 16, 2015 Hey it isn't something as simple as a dicky switch controlling the 4WD indicator light is it. Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7516899 Share on other sites More sharing options...
blind_elk Posted April 16, 2015 Share Posted April 16, 2015 Have you checked the fuse? Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7517122 Share on other sites More sharing options...
MozzMann Posted April 18, 2015 Share Posted April 18, 2015 Good point Mr Antelope , I have seen systems that use power to keep the 4WD OFF and if there is no power then it drops to fail-safe mode with 4WD ON. Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7518208 Share on other sites More sharing options...
GTR_JOEY Posted April 19, 2015 Share Posted April 19, 2015 Have you bled it Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7518708 Share on other sites More sharing options...
KiwiRS4T Posted April 19, 2015 Share Posted April 19, 2015 Its on when the car is turned on - its at the mark for max fluid thanks - the car has been sitting for like almost 4 years when I got it. One possible cause is insufficient level in the BRAKE fluid reservoir (I'm speaking from experience here). Link to comment https://www.sau.com.au/forums/topic/455725-4wd-light-on/#findComment-7518873 Share on other sites More sharing options...
