Hey Guys, Always hated the big Hamburger on the front of my 370GT.
Swapping to Infiniti badging doesn't appeal to me either.
So, I did this.
Basically I modified the Nissan Hamburger.
I used a boot emblem & stacked it.
Cheers.
https://www.sau.com.au/forums/topic/455833-v36-custom-grille-emblem/
Yes, I do to,
was actually tossing up between emblem less & modding the Emblem..
Great work modding the emblem. In my opinion I would stick with the Nissan / Infiti logo or have no emblem at all... Your car is stunning and I feel this custom emblem devalues it by "tarting it up" unnecessarily...
Edited by Sikahalv
Part of the reason for modding just the emblem was its 100% reversible.
As it stands, the grille is coated in Plastidip, easy peel off & back to chrome.
Emblem is in Epoxy, but is a simple replace with a new Nissan item.
You'd be surprised how good it looks in the flesh btw.
The alternative of going emblem less (which I was also tossing up between) is not reversible however, as it involves fiberglassing in the missing sections of grille from behind the badge.
Just something different, might keep it like this for a while, or maybe not, we'll see.
Unfortunately I'm cursed with a big dislike of the original grille emblem & dont particularly care for the toffy nosed infiniti badging.
Imo even a grille with a hole in it would be preferable.
Cheers.
There is a US website that made customer grilles, lips, spoilers, etc for G35/G37's.. I can't remember for the life of me what it was right now.. but if I come across it again I'll post it up in here..
Perhaps someone else may know the site I'm talking about (not outcast btw), they do a lot of carbon stuff as well (pricey, but look to be good quality).
Anyway I'll get back to you if I find it again :)
A grille with the skyline "S" logo like the older models wouldnt look bad in my opinion. Provided it wasn't overly large and gaudy looking...
Either that or perhaps "Skyline" or 370GT located on the lower right hand side of the grille Hakosuka style
Tokyo-Nostalgic-Car-Show-2010-47-Skyline
After 3 weeks my modded emblem sh1ts me now.
Its just to friggin big.
Part of the problem with the hamburger originally was its obese size.
I like the idea of the 370gt on the side Bliksem.
When I get a chance I'll re-do it as emblem-less & maybe try a side emblem.
All good fun.
Cheers.
yeah if you could do an embless-less grille, i'll debadge my whole car and not worry about this half half infiniti nissan badging i got going on lol
All good fun.
Cheers.
  • Like 1
