Hey Guys, Always hated the big Hamburger on the front of my 370GT.
Swapping to Infiniti badging doesn't appeal to me either.
So, I did this.
Basically I modified the Nissan Hamburger.
I used a boot emblem & stacked it.
Cheers.
https://www.sau.com.au/forums/topic/455833-v36-custom-grille-emblem/
Yes, I do to,
was actually tossing up between emblem less & modding the Emblem..
Great work modding the emblem. In my opinion I would stick with the Nissan / Infiti logo or have no emblem at all... Your car is stunning and I feel this custom emblem devalues it by "tarting it up" unnecessarily...
Edited by Sikahalv
Part of the reason for modding just the emblem was its 100% reversible.
As it stands, the grille is coated in Plastidip, easy peel off & back to chrome.
Emblem is in Epoxy, but is a simple replace with a new Nissan item.
You'd be surprised how good it looks in the flesh btw.
The alternative of going emblem less (which I was also tossing up between) is not reversible however, as it involves fiberglassing in the missing sections of grille from behind the badge.
Just something different, might keep it like this for a while, or maybe not, we'll see.
Unfortunately I'm cursed with a big dislike of the original grille emblem & dont particularly care for the toffy nosed infiniti badging.
Imo even a grille with a hole in it would be preferable.
Cheers.
There is a US website that made customer grilles, lips, spoilers, etc for G35/G37's.. I can't remember for the life of me what it was right now.. but if I come across it again I'll post it up in here..
Perhaps someone else may know the site I'm talking about (not outcast btw), they do a lot of carbon stuff as well (pricey, but look to be good quality).
Anyway I'll get back to you if I find it again :)
A grille with the skyline "S" logo like the older models wouldnt look bad in my opinion. Provided it wasn't overly large and gaudy looking...
Either that or perhaps "Skyline" or 370GT located on the lower right hand side of the grille Hakosuka style
Tokyo-Nostalgic-Car-Show-2010-47-Skyline
After 3 weeks my modded emblem sh1ts me now.
Its just to friggin big.
Part of the problem with the hamburger originally was its obese size.
I like the idea of the 370gt on the side Bliksem.
When I get a chance I'll re-do it as emblem-less & maybe try a side emblem.
All good fun.
Cheers.
yeah if you could do an embless-less grille, i'll debadge my whole car and not worry about this half half infiniti nissan badging i got going on lol
All good fun.
Cheers.
  • Like 1
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
