hey guyz just wondering if someone could please give my car the r34 GT-R from 2fast 2furious Colour and all the decals (including all the brands on the bonnet). So it will look like the r33 version of it.
Then can u cut out the car and put it on a black background with the 2Fast 2Furious label on it. I know im asking alot but thx if anyone is willing to do it:D
Thx in advance
Chris :D
https://www.sau.com.au/forums/topic/45607-do-up-my-car-d/
