Hey guys been lurking for a while.
Just starting a build and wanting to know what is the deal with race pace tein suspension.
From what I read its the ducks nuts for street and track duties that won't rattle our your teeth.
But is there another option or is this is it. Just wanting to compare all products be for pulling the trigger.
https://www.sau.com.au/forums/topic/456491-racepace-tein-vs-others/
You won't find an off the shelf coil over any where near as good from what I've / been told. Especially when it comes to all round usability ie track, drag and street.
I just recently bought a second hand set off tein from Japan, they will be getting the Racepace treatment soon
I have Nismo R tunes ( Ohlins Flag Rs ) i bought of Piggaz that i changed the spring rates on and played with the bound and rebound setting and i can't complain about them, i think they are pretty good, they don't rattle and they absorb the bumps really well given the suspension travel these cars have or lack there of
I just installed MCA reds in the Evo, so glad I did. I was tossing up between Shockworks and MCA for months. Both offer great service and in house re-valving, replacement springs and parts are always on hand for very reasonable prices.
I went MCA in the end due to their time attack results, they definitely know their shit.
  • Like 1
I've had Racepace TEINS in for about 8 years and have nothing but good to say about them. Lots and lots of track time and very flexible with adjustments (moving between Winton, Sandown and PI). They are able to control big spring rates well, particularly with the valving changes they make its a huge improvement in bump over a lower end bilstein for example.
Now I'm really excited about getting them! :D
I have Tein MonoFlex on my car, and although they are very good, when the time comes to move them on, I will be getting some MCA's......after getting to know Murry and Josh at MCA you realy get to realise how much of an understanding of suspension they have. They punch well above their weight in building winning shocks for track, rallying and more recently time attack.
My bad.....still same brand
Was more about MCA brand as an option.....
I have TEIN RE's on my car - they are a large monotube shock where I think most of the versions here locally are much smaller twin tube designs. MCA's are v. nice but $$$$
How are the MCA red for street driving? A mate has them in his S15 and reckons they're pretty harsh for the street but good at the track. MCA blue might be a reasonable compromise for the street?
My reds are fine for the street, although I went 1kg less front and rear than what they recommended for the track. They are about to release an intermediate purple Xover version in between the reds and blues which may be more suited.
So I messaged MCA and got a reply from Josh.
Let me start by saying I can see why people like them, Josh's customer service is second to none.
He told me there are the versions of the new coilover that is between the red and blue series.
X-C - comfort road orientated, great ride quality
X-D - drift orientated
X-R - 70% track 30% road setup, great value for the level of performance you get and still quite streetable.
So I asked about a red series that is valves or set up the sane as the X-R series and what would be the difference.
And I received this great reply.
"Hi Mitch
Yes in theory, with the right kind of requirements, you could end up with something similar to the X-R valving. With other models of cars that have mcpherson strut type suspension, like Subarus, Evos, Silvias, etc, there would be many different external features, however in the case of the skyline being just a typical coilover type of suspension there is much less you can do externally, but that's also why they are much cheaper than the other types of cars. So the main difference with the Reds if the case arose that the valving was to be similar to the X-Rs would be that the Reds go through a much higher quality control system.
We take a lot of time with the build of the reds, double checking everything and making sure each component is perfectly clean before assembling. They also do still benefit from a high grade oil (the same as used in our golds) which handles high temps a lot better. Then each shock is thoroughly dyno tested. We run each one on the dyno at various damper adjuster positions to make sure everything is working correctly, we then compare the shocks left to right to make sure that they are even and there's no slight differences. It is also used as a test for seals as they are put under load, and gives everything a heat cycle and potentially frees up any initial friction there might be before installation. If at any stage something isn't exactly how we'd like it, it's pulled apart and fixed and re-dynoed. Plus there's the time taken to make sure that valving similar to the X-R would be ideal for you in the first place.
Hope that explains it ok.
Let me know what you think.
Regards
Josh
These arrived today,
I'll let you know what I think but my comparison is some shitty old school jap twin tube design which has springs too low for the shock and overheats after 3-5 laps. Once the car is hot it stops controlling the spring and the car sways, pogos and slides.
10KG front
6KG rear.
Josh suggested 12/7 or 12/7.5 from memory. I just wanted a bit softer while keeping a slightly stiffer rear end. Last outing I had too much understeer so we will see how this goes
One of the reasons I went MCA is because Josh said that If I don't like the spring combo I can send them back and swap them out at no cost. As long as they aren't damaged he will exchange them for free. He didn't specify a time frame on this but I imagine it would have to be soon after they are installed.
Buying the wrong springs isn't the end of the world anyway as they are $50 each brand new from MCA.
If you are really hardcore or if you love pulling your coilovers out you could even have 2 sets of springs!
Edited by Blackkers
    • Threads merged. Only need one for the same question.
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
