  • 3 weeks later...
paddleshift holinger?
its about $24k for a brand spanker holinger
add on gear read out display and subframe closer to $30k
and i think the paddle shift option is an extra $5-6k
plus shipping and installation
got 2x 32 builds going. Shitter is LS powered for track work, cammed, new tr6060 box with upgraded synchros, nismo lsd, AGI cage and basic suspension goodies.
No 2 is my good one, 26/32, gt42, t400, gtr rear etc etc, 7yr build so far
  • Like 1
Nice builds Corey! Got any pics to share?
Mine is sitting on axle stands at the moment as I'm changing suspension setups. Might give it a respray later in the year and then think about swapping out the current turbo setup for a precision turbo of some sort....6262, 6266 or even 6466 .... dunno yet, need to do more research! :D
2.6 or? i think simon has shown the sweet spot for a 2.6 is the 6262
No pics at the moment both shells are bare getting ready for paint. Both been on the back burner for the last 6 months due to being busy at work. Will get some up when I start tinkering again.
Damo, go the RPF01's they are nice. Why the hate for the XT7's?
I think they look good on other cars like a 4 door 34, I think they have just been on the car 2 years and i am after a change although car has only been running ~ 6 months of that hahaha
on that just purchased a set of RPF01s in black should arrive in the next week or so
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
