Free for under 12's so cheap night for you ;)
Byo frothies in cans. No glass
Hey hey! I have an impressive beard for a 12 y/o I must say :P
Can do frothies in cans, Suntory Magnum Dry, ~$56 for a cartton of 24 x 500ml cans with 2 standard drinks per can. I think we can make that happen.
Suntory do good whiskey aswell Lachy
Going anywhere nice and muddy Dale? Would you like a hose down afterwards?
After last night I'm not sure whether I want to drink again lol
lolz
fkn miss you guy :(
but yer, soooo much mud, got knee deep while standing on the pegs at one point, also got smacked on the thigh with a branch at 80kph+ so a massive fkn bruise as well
but new rear tyre is officially a "good" thing
2 weeks knocking the wax off on tarmac, I was starting to think I had done a very silly thing (knobbys are awful/scary on the road)
but in the dirt its now a bit of a lunatic thing to ride :cool:
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
