Was that in japan or duty free on the way home?
Got it on the way home.
I did bring home a real small bottle of saki and suntory whiskey which both go down a treat.
Scored a bottle of Russells Reserve the sphincter of the universe the other week, found it at Eaton Tav of all places
Which rum would you guys recommend to start with? Not sure when I can try it though, just bought 3 bottles of scotch to try out :rolleyes:
I'm going to grab a bottle of Sailor Jerrys
A job? Yeah.. I fixed the hose, replaced plastic joiners with brass. No more leaks. Changed clamps worm clamps. Thank godly father in law is a mechanic by trade and was able to help otherwise this would have taken much longer. Got some new tools too!
Oh and we drove straight past some cops during our test run. Big innocent smiles.
Edited by Manne
  • Like 3
Nah Trev, no plates. I'm doing all this work to get it over the pits. I need to fix my tachometers (rev, fuel and turbo) I also need to mesh up my grill and strip the shitty old bubbly tint off the back window. Then it's ready to go over.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
