No call from c-red so no info yet. Asked if i coyld be there for the dyno run but the guys said sorry :(. Mate of mine said usually reason they dont like people there watching as usually have issues or probs and they just wana get the job done, which is understandable
Some other mechanics do the same. Sometimes I wonder if they don't want people around cause they aren't actually doing anything :glare:
Customers become a liability standing around, if something were to happen they'd get in trouble.
And also customers get in the way, ask a million questions, pull you away from the job etc. Happens a lot here and then they get all shitty cos the job has overrun
Yeah i looked at it from this point of view when i asked thats why i was ok with it.
And morning everyone happy tuesday
Yay!, Four hour shift at work, then I need to take the skyline to get the fuels and go out and get some stuff to attach my license plate properly.
Make sure you get with frangipani flowers ok [emoji6]post-139458-14643072023664_thumb.jpg
  • Like 2
Nothing against customers wanting info on their cars, i don't mind it at all. Just makes progress on the cars slow
Totally get that, would rather them tell me that than making an excuse of space and noise and not safe >.> I used to ask customers to go away when I was working at the workshop.
And just like that i jinxed myself. Customer came in guns blazing because we have gone over time
Push the car onto the street and tell him to GTFO!
Fkn MA61 Poopra giving me dramas. Customer supplied brake pads - WRONG! So I ordered some from Veales - WRONG! Ugh, can't take a trick.
In my defence though, the customer supplied EBC pads and I looked at their online catalogue and his part numbers weren't even similar to what was listed. I triple checked my Bendix part with Veales, but nope it was wrong when it got here.
Make sure you get with frangipani flowers ok [emoji6] ImageUploadedBySAU Community1464307201.367454.jpg
Where can I get those? Each flower is +5hp right?
Drove around all arvo Shea running well. I'll see you all at the meet tomorrow night! Bring dem stickers.
  • Like 1
Oh meet and greet tomorrow night 7pm start near Joondalup , might have to catch up with you , Zookey somewhere else after dinner if that's ok ? I'll bring the stickers [emoji41]
Oh I can get you the frangipani plate holder if you like and its for free [emoji13] but you must have it up ok ? [emoji13]
  • Like 1
Honestly bro only 18 bucks for 4 stickers, support trev who went thru the effort of making said stickers. Now im not saying your being cheap but dude your being cheap ;)
(I just feel that trev will offer his fyp in this)
  • Like 1
Yeah thats fine [emoji6]
  • Like 1
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
