Lol dishes only if it was that easy.
Yer I've seen this ad hmmm
....... nice im just concerned about the high mount and whats it tuned for lagging down low crazy power up high. Opened airbox pits wont like.... thinking its been thrashed abit..
This is his second ad i did contact him 2weeks ago as i wanted to see it no pick up calls no email no sms.... just 1 you got to see it in person some magazine wank off bla bla bla copy and paste from his ad...... no sms after that. Made several attempts of contact.
I love the vspec 2 n mspec as there r the only one i would consider.
I may give another go at contacting him in a week or so.
  • Like 1
Manne so what tool did you end up using?
I always find this handy as the straps never work or the metal band crimps.
But this guy at a tool shop once showed me this wired tool the looks like long nose pliers but with metal spikes that bite in he said its messy and last resort sorry can't find a pic for that 1
I like the chain wrench
Edited by pol1on1
They've only got 1.1's I don't know how to gap. Unless u go iridium. What gap am I meant to have?
Go 0.8mm
Up to 1.1 may be ok for your car for the time being but will be more prone to missfire and you'll lose nothing by dropping them a bit but everything to gain.
I tap them gently on the side of a hammer and check with feeler gauges.
About 6-10 gentle taps gets me from 0.8 down to 0.6
So considering I don't drive much at all (probably 10,000kms per year) I should just get platinum/copper?
Also, morning all, nice, cold and wet this morning!
I'd never go platinum personally. Copper are cheap and on standard car should do 20-40k km's or more. Iridium might be good for double that
I use coppers (same as skyline plug) in my work car and just changed them last month after 200 000kms so on non turbo they are good for ages
  • Like 1
For those wondering, Ellie said she's tired aha.
I need to re-seal my seal job, as this cold/warm weather created small gaps on it :). I'm also going to gap my spark plugs today and throw them in the car.
Thank you for the translation [emoji28]
You're always tired. Supplements?
Hahahahahaha My day is pretty full on :) , up at 3.15 am and won't be home until 7.45 in the evening or later than that , depends on how busy with the events / meetings. and top up with Daily workout at the gym at least for 1.5 hours :) loved my cardio !
  • Like 1
Yeah, you're abit crazy with fitness =P I on the other hand get lazy and just forgo my workouts lol
  • Like 1
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
