12 hours ago, PranK said:
Yeah I have a feeling the app config/data might be cached. I'll get to that but we have a nice new responsive front end which works perfectly on mobile so they can use that in the interim. Thanks for letting me know.
Response from Christian about you guys having problems with the app not working
  • Like 1
4 minutes ago, z00key said:
awesome thanks for that, as for 26 is that a RB your talking about?
Would anyone say this is a good deal or not worth it?
http://www.gumtree.com.au/s-ad/kewdale/engine-engine-parts-transmission/rb25-turbo-set-up/1117376932
Gallo 24 :D:D
Yeah rb, needs work but got it at a good price
Z00key what power range do you wanna end up at?
Being a g2 it might not hit 400@wheels. But would be responsive.
Not a bad price if in good condition. Send the link to "hypergear" and ask his opinion and price to do an "update"
He is good to deal with ;)
  • Like 1
400 is kinda my want figure as it is my daily but just under is ok.
Back in the day they were made g1-g4
G1 was virtually standard and g4 did 430@wheels but laggy.
G2 and 3 were best IMO but I never looked at g2 personally.
I've "upgraded" mine once and only paid for shipping. He offered me another upgrade too but I refused. Now that's awesome service really.
He will have best knowledge of that exact model
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
