If you got time to charge it buy a ctech battery charger it has a few modes plus winter motorbike recon 1 more forgot and its all 7steps they not cheap btw thats what Ferrari stick there red sticker on. Oh and you can't go wrong with a battery jumpstarter. :)
  • Like 1
This is the one i have i got the old model i think a new one is out with 1amp more
https://www.google.com.au/search?q=c+tech+battery+charger+5+amp&hl=en&prmd=ivns&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiM6Jad9avOAhWIpJQKHVIxAvwQ_AUIBigB#mhpiv=0
Btw yellow tops battery are sick that what we use on site for all mining equipment eg dump dozers shovels.
  • Like 2
Cheers guys the battery survived, I bought a jump starter 1900 Amp, kicked over easy!
Checked out the tool kit while I was at SCA, it looks ok but the drawers are a little flimsy but for the price I think that it is ok.
  • Like 1
Morning all, I think im gunna go buy a tool box/chest/trolley today what are you guys thoughts on this set?
http://m.supercheapauto.com.au/Product/Stanley-Tool-Kit-Mechanics-133-Piece/322115
Good for the price. You will need a 1/2 socket set eventually too for the bigger, tighter stuff
  • Like 1
For me the dream would be my own car hoist, tools i can borrow lol
Fark that. Realistically how often do you need a hoist? I use my tools atleast every second day for something on the cars or around the house
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
