9 hours ago, t_revz said:
My favourite station is Tokyo Teleport :)
The toyota museum was shut both times i went to this station. The shopping centres were pretty good though
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
