Ahhh thats about right !!!! My luck is like telling someone not to breath.[emoji25]
So i emailed NENGUN that i want the r33 gtr interior gear consol dash OEM/Nismo carbon fiber trim.
This is the email i get back...[emoji30]
1485811784761.thumb.jpg.cd5db4699153c55a
4 hours ago, pol1on1 said:
Ahhh thats about right !!!! My luck is like telling someone not to breath.emoji25.png
Do you have a genuine part number?
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
