Haha, I'll see what I can do but will definitely get you guys a table for soft launch. Hope everything goes through fine, just having some issues atm with leasing etc...hence been abit crazy busy
  • Like 1
28 minutes ago, t_revz said:
i probably wouldnt get a 200 series unless they were 50k
Yeah, probably worth that.
Brand new, top of the line would be worth more, but that depreciation though.
