f**king shit dream boats, Should be able to get it off easily. FYI you will need to acquire a permit for the intercooler as a modification been done to the car.
There's a form online some where if i get a chance to look today I will send you a link.
Wtf first I have heard of it, Mark didn't mention that just said to put mesh on it
Just now, Shoey84 said:
But it also depends on where you take it too and if there nice about it.
I went to the place in Welshpool, was polite to the guy, we talked about the cars when they were new etc...he even licensed it with the turbo timer on.
  • Like 1
1.2 MODIFICATIONS REQUIRING CERTIFICATION UNDER LA CODES The following is a summary of modifications that may be performed under Section LA:  Fitting engines greater than 120% of original power and/or engine mass;  Fitting performance engines;  Fitting engines from non original equipment sources;  Installing a supercharger or turbocharger; and  Modifying the engine and engine components that results in an increase in engine power of more than 20% and/or affects exhaust emissions.
https://infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP3_Section_LA_Engine_01jan2011_v3.pdf
My thoughts are if you have all you paper work taken care of they cant pick on anything.
Also Matrins car is in very good condition just the mods can be picked on if they decide to do a emissions test.
18 hours ago, t_revz said:
doctors orders?
Nope just my knees starts clicking after I do high impact or if I walk up and down steps too much. Trekking to Everest Base Camp was fun hahaha constantly thinking when my knee is gonna call it quits.
18 hours ago, shoey85 said:
f*cking p1gs stickered the R34 tonight while the wife was on her way home! Didn't like the lights and they think the engine leaks oil WTF!
Gotta hate the bacon, got nothing else better to do.... Bad news here too, something's let go on my car and its using alot of oil and occasionally blows lots of smoke ?
buggar, rebuild time more powah!
  • Like 1
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
