Wtf how dare my phone change God to rajab. I find this deeply concerning?
There are a few words on the forum that auto change due to language or just for the lulz.
Such as tur-key becomes the sphincter of the universe
  • Like 3
Compression test shows
1=150
2=155
3=155
4=150
5=155
6=150
Intercooler is full of oil again, proberly about 2l worth lol.... catchcan and overflow bottle is oil but relativly empty. Guess its new turbo time, injectors and ecu time
1=150
2=155
3=155
4=150
5=155
6=150
That's good news. Thought it may have been a ringland as they are so common.
When I stripped mine at 180k it had 5 broken ringlands but only 1 was letting oil past
has any one got one laying around there not using. I would like to see if i can get my dash boost gauge working again. 58d5c9477d71d_boostsender.jpg.ea7764faf13d61475f1a005c6bfd09bb.jpg
Ahh so that what it is i was wondering why i hot a floppy tube and gauge not working. I still will be maxing it out tho [emoji12]
I suspected ringland failure amd it still mite be, but to have comps that high i think there ok. My motor got a work out Thursday night so i suspect that finishwd the turbo off. Original turbo from new on 176k, its done well
  • Like 1
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
