What power?
I normally cruise around at %25-35 and turn it up for every dickhead that thinks his falcoon or comonwhore auto is awesomeness! Telling his missus told you we could beat a skyline!!! Up to 30 kmph. Till the twin plate has grabbed!
  • Like 1
Wtf thats gotta be a error? Tempted to buy to invest in? Anyone wana loan me 20k?
Wow Ive always wanted one of these. That is a crazy price. The33s have gone up again from a few years ago I was looking at them for about 23000 a few years ago. That seems crazy for a victory spec!
  • Like 1
its probably either sold or a error in listing E&OE :P
Do it, say its for the kid [emoji6]
So long as you can do v-lcds, turbo's and mechanical stuff yourself this is insane. I was looking in wa for ages for a good r33gtr but they have been going for over the 25000 again. Have to be happy with what I've got after spending nearly $4000 on top of $12000. The lure of the legend. Gtr!
  • Like 2
I got 19psi on stock internals 412hp just slaps some sticky slicks on and say bye bye to the lumpy v8 that thinks his cool!
Haha
Haha
I would assume 412 at the crank. Pretty impressive. Who tuned i?
Haha
My wife has a ba xr8 6 speed with a cold air intake Lovell Springs Koni shocks lowered on 19"s and adjustable sway bars with a straight though 2.5" twin. I murder it. Could be something to do with with the driver. She shifts the skyline at 5000 and thinks it's scary. Haha
  • Like 2
Wow is that a 25 or 26?
P.s. I'm about of a noob with the forum and the Nissan. Would love to see it in action? Do you go to whoop ass Wensday? Was hell proud of what I'd achieved till I seen that figure! Must be a animal to drive!
8 hours ago, pol1on1 said:
Holy moly this probably will get sold in a week just got listed today! I recon Friday it will be sold.
Check it out
https://carsales.mobi/cars/details/_/OAG-AD-14505452?WT.seg_4=AutoAlert%3BPCAA
Thats proberly about what there worth, anything more than 20k is over priced unless its mint with low milage and minimal mods
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
