Hai kunce!!
Vreaking in a new eaton 9 speed with a super duty organic clutch in the heavy tilt. I'm ending my days looking like popeye with bells palsy.
Scarnon with youse?
2 hours ago, t_revz said:
Hey Dale!! Drinking sake with the mafia
Fly home on the weekend. How's the family? Due for catch-up soon
Keen as for a catch up dude. I am still spewing i missed the last one :(
Family is good. Loinspawn are starting to spread their wings at last, so i have more time to spend pantless at home, and i think that is a win.
  • Like 1
