DSC_0288.JPG.2d612e8f3a4019abce5b21dd450f2561.JPGCheck the tube out. (from the Dennis) Intercooler to manifold intake pipe on the charge air or boost side were 4" o/d. Because the intercooler outlet and the manifold were cast pipes the I/d of the cast pipe was approximately the same as the I/d of a 3 1/2 inch 16 guage tube. They have had problems with the 4" Ali tubes being worn through and cracking from the compressor lines of the Cummins engine wearing through and losing boost pressure and rattling. I left the tube running off the intercooler at 4" like a plenum then reduced it to 3 1/2 to clear the chassis rail and compressor tubes. Still had to press a flat in it for clearance at 3 1/2 inch o/d s/s. We had to lift the chasis from the leafs just to be able to manoeuvre the tube in with a porter power because the 2ton forklift couldn't lift it. Developed 3 tubes from 316 s/s, done the drawings and jigged it up. 2 days. Tighter than a nuns I'm there. Mental.DSC_0292.JPG.934e33e1b2456435ed5f1f9d61aedce4.JPG
Hey if i were to ask nicely what would I be looking at roughly for you to make me up a intake pipe (replace the plastic/rubber one) with i nice one like this. Your fab work looks awesome
Thanks. At work we sell all the s/s m/s Ali tubing and bends. Plus all the silicone hoses. Clamps, reducers and what not. I'd have to have a look at what you want then get you the gear at cost pricing. We only do heavy duty or mainly diesel stuff at work and I wouldn't recommend the labour costs! But would be happy to have a look and try to help you out! I've got heaps of stuff to fix on the 33 but going into work on the weekend bums me out. Is it 3" piping?
It would be from turbo to air filter chances are would be same as your 33?
Scottynm35 makes them from Ali n ships them over. He has a jib set up to suit most models. He also puts in small return pipes if required for blow-off valves and whatever else is required. I'd reccomend waiting til you replace turbo to reduce modifying twice. I got mine from his aswell as hundreds of others
  • Like 2
Ouch!
Ouch!
Sorry didn't mean to cut you out, just thought it might be more effort getting angles aligned with his car etc where someone has already figured it out and charges decent price for ppl on Sau.
Sorry mate
  • Like 2
Sorry mate
All good. I've got 3" Ali off the intercooler and 3" s/s In the engine bay. The 304 s/s is more heat resistant and less prone to cracking than aluminium. The aluminium will get a better smooth penetration on the inside of the tubes compared to stainless unless you purge weld it. Also aluminium is lighter. Or you would have to use different s/s filler rods that we don't have at work anyway. No cut out at all. I've still got loads of jobs on the car that need to be done at work and can't bring myself to head in on the weekends. I did my apprenticeship at opposite lock/outback accessories, then k&n fabrication as the foreman. I've been at exhaust fabricators/ engine protection equipment for 18 years as the foreman. If someone else has it jigged up for cheap go for it.
That looks awesome, only difference on mine is wouldnt need the maf. If you could give me a ball park figure (you can pm me, private message) or just post here as im sure[mention=143902]shoey85[/mention] and[mention=143051]manne[/mention] might also be keen?
Nah I'm good mate, mine doesn't need fancy pipes
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
