1 hour ago, colin.ssc said:
Yea 7 would be fine. I'd say 6s might do it as well. Just depends how soon you need it and how much you want to spend.
Apply don't supply 6s to retailers anymore. Would have to be super lucky to get one.
Or 5SE? Even smaller screen and have 6s parts. Not sure if its still on the market for sale @t_revz
Not really a thing, we get given maybe... 1 every 3 months.
Apple don't really support their older products, also word on the street is that the SE is about to be completely ditched, not getting the next software update (To be confirmed).
If my phone actually had some memory I'd not bother with mine but it can be frustratingly slow after taking a few photos. Also can't update so lots of apps aren't supported.
Hopefully find the wife's when we get home then we have time and don't need to rush
I'm after a dishwasher too so might kill 2 birds with 1 stone. Missus lost hers 2 days before going to Japan so will be keen to do it ASAP
I'm not "hip" and up with technology when it comes to phones. Currently have iphone 4 and forced my wife to stick with hers too. Haha
If you like the size of the 4 and don't want a bigger phone you can go the iPhone se
Ditching the se at this point would be silly on their part considering how well it sells/sold globally. They support the phones for 3-4 years after initial release.
They've made it a prepaid phone now. Locked to Telstra.
Just now, t_revz said:
halfway home, in singapore.
so far smooth sailing. hope its not too cold back home
You might wanna check prices of phones over there. Might be decent. iPhones have global warranty anyway.
It's not that cold here at all. Nights are abit chilly =) but days are still on the higher end of 20s =(
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
