Blah first day back at work in 3 weeks.... the struggle is real....
You love it. I spent all day scanning in a vibro shear manual from 1975 into pdf's then converted into a word document cropped and resized it to a4. 3 hard copies of all manuals for all machinery. 1 on the machienes, 1 in my office and 1 in the big bosses office. Did jha's for all machienery as well. Nice change from welding! We concreted in a totem pole today 1m in the ground for the railway line 3" 2" etc solid bar for hammering lifting pulling and stretching. 8" I beams welded on for strength in the concrete. Nice change:-) loved it!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
