Also got a photo of each spark plug
My opinion is plug photos are irrelevant except for checking last RPM.
ie- your plugs look richer on 3+4 but that could be just at idle.
I've pulled plugs after idling,cruising and on the highway turning engine off at 6k WOT and they look very different.
What plugs did you fit afterwards? Coppers or iridium?
Nah just did the comp n plug check
Yeah i do let it run a bit before i park up slow drive up the hill n cool down probably a good 2mins worth
Thay r PFR6A11 Laser Platinum Plug
Maybe 3, 4 could do a change coz of platinum worn a bit on edge but there not much KM on it.
Don't waste money on platinums.
Throw em in the bin
Sub 400hp I'd say bcpr6es coppers
Above 400 run 7's
Went to the city stage of the rally today. Way more skylines running in the mornings classic car section. Had some 32 33 34 gt-r and gt-st's Heaps better than the Malaga and Whiteman park stages. 5 hrs in very mild sun and strong wind. Curse of the ranga, unbelievably got burnt.
know them feels...
thinking of the sun gets me burnt
  • Like 1
On 8/12/2017 at 0:48 PM, pol1on1 said:
Yer i used deconjestion spray that solves bit of it but xray shows that i had a defomed canal that worked as a 1 way valve basically not allowing suction to top sinus (above eye) when landing which made alot of pain the worse I've is numb jaw striking pain down neck and numb collarbone with eye feeling like exploding that was every second swing landing for me.@manne I've read you have some similar issues
Yeah dude, Three weeks and i'm feeling much better but there is still a little bit of pressure around the nose/eyes that flares up from time to time.
I'm currently using a Sinus cleaner thing, it's a bottle with a thing you stuck up your nose and squeeze, and it flushes them all out.
Agree with you though, the Pain is UNREAL, I was knocked out for a good week, sleeping 20 hours a day, and then somehow, my chest became all messed up too.
Steroids, Sprays, Antibiotics and 3 and a half weeks, but i'm still not better.
know them feels...
Panicked when we got to Toodyay. Jack was like there is smoke coming out from under the bonnet. Wtf. Bonnet was a bit hot with no blanket underneath it was steaming the rain over the turbo off the top of the bonnet. Was just running up the hills in 5th and loading it up on the way there with the boost controller off. Used 4th for the hills on the way home at 14psi no probs. Different animal to the 4,9 5.8 5.0 and 5.4 lesson learned. Bugger all torque at low revs. think I will get rid of the 200cell catco oval and go to the venom 100cell with the 5" substrate. Tuning is beyond my nuts and bolts ability. Any thoughts? We ran sweet to and from Albany and did 1000kms pushing it hard. The original 100 cell metal cat copped a massive smash over a trainline bump at full speed the substrate came loose and flew into the exhaust melted and killed it and we popped a intercooler hose because it blocked the exhaust.(the weekest link) have swaged pressure tested and redone all the tubes and hoses with a intercooler flush. Would I need to retune between replacing the cats? Any advise would be appreciated. Thanks.
I will come Eli!
know them feels...
I will come Eli!
Don't get me wrong she's running and pulling hard at 18psi still. All temps and pressures are normal. Just seems to have lost a bit at say 6000 to 7000 under full load? Trevs? Kizza?
Hows weekend for Everyone ? Next week Saturday - Any idea where we going to meet up before head Down to barbagello ? Cruisinnnnnn All
Together from joondalup ?
Whos going ?
Yeah 84 and I will be there, my mate wants to come with so I'm gonna be in the Prado
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
