11 hours ago, colin.ssc said:
Farkkkkk that sucks  you guys ok?
All gd here, cars now at my mates workshop... keep ya fingers crossed lol there doesnt look to be many gd skyline out the at the mo
  • Like 2
My wife says its cursed
Man how many people in perth just mash the brake from no where. Was a crash on tonkin roe intersection yesterday. Had too slow down to 20kmph on the on ramp from people staring. Is a 100 zone. Wtf.
  • Like 2
Runner necking....
Anyone see the crash on the news 3 weeks ago? A ute rolled through the bush cuz she was too busy looking at the crash on the other side to notice the stopped traffic infront of her lol
  • Like 2
Runner necking....
Yeah mate I had the pipe rack on the ute on the way home with a 14" catch can 2 x intake tubes and a 3m outlet across the top all strapped down. Went from the hunge down to stopped because they were all looking at the crash 300m away on the opposite side of the dual carriageway in full storm. The dude in the Jeep needs a goods punch in head. Had a guy in a land cruiser pass me on the left on roe hwy I was doing 120 he smashed the landy between 3 cars in and out swerving then fully cut me off kept jamming on the brakes and pulling fingers at me down to 60kmph they are on f**king drugs man. It's bollocks.
  • Like 2
Every light in the xr8 or the Nissan there is some tosser in a snot box trying to give you there best 200h.p. At the crank. Then if you take off normally they think they have won and slow down in front of you.If you take off quick they pound your hammer like you never won and want to crash into you.if you launch at 4000 spin the wheels and sideways too 100kph you will be arrested. Welcome to Perth.
  • Like 1
I've been going up Tonkin quite a bit recently, and Its so depressing when I noticed Tow Truck drivers just park on the side of the road waiting for an accident, because it happens there so much they make a profit doing so.
  • Like 2
There only making money off of people who cant drive. I had a idiot last night on the kwinana outside land to inside lane to get off at armadale road... crossed 4 lanes of traffic to then decide that he wanted back on the freeway and crossed 2 lanes of slip road and the emergency lane to get back on. How there wasnt a acvident i dont know
The biggest issues with perth is its speed limits and people being stingey. People pay as little as possible for tyres, corse ur 20 dollar plastic tyres arnt gonna grip the road and not enspire confidence. How are you supost to drive if u cant feel what the cars doing??? Specialy in the wet.... and the speed limits, iv never understood why ud make giant v8s and have such slow limits. At 100kmh my concentration level is minimal as which i think most peoples is too. Lots of unconcentrated frustrated people makes for dangerous roads.
  • Like 1
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
