50/50 meth-98 mix. E85 is hard to come by now dows and vp racing fuels are silly money
Just use water meth injection and stick to 98, optionally add some nitro methane to the meth tank for extra kick. I think it's 100ml per L of water/meth mix for 30ish hp, poor man's tiny dry shot.
  • Like 1
Im not sure id be alowed to use nitro methane. Sure would be nice tho
Nobody else needs to know it's got a little nitro methane in the wmi tank. Just get it tuned with the mix you want in it, can pick the stuff up in 5L containers from hobby shops as it's the same stuff you use for nitro rc car engines, that's where I used to get mine, same with the methanol.
  • Like 1
Sneaky, i like this alot
Anyone awake?
Yep have been doing a re-tooling. Feel guilty for the old sidcrome. Have had her for 25yrs, and was second hand then. Thought the kinchrome was pretty close to R33 gtr-lm spec championship blue.DSC_0290.JPGDSC_0291.JPG
  • Like 2
Yep have been doing a re-tooling. Feel guilty for the old sidcrome. Have had her for 25yrs, and was second hand then. Thought the kinchrome was pretty close to R33 gtr-lm spec championship blue.DSC_0290.JPG.2da6d7e527486b1461488b13ed0ee351.JPGDSC_0291.JPG.248a9ed41cfc8c91729f6b61c1a2269b.JPG
Run out of room already. Bummer.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
