On 28/09/2017 at 11:11 PM, Manne said:
I don't want to be that guy, but, I was taught that you're not supposed to buff a car for at least 3 months (normally 6) because the paint has to de-gass.
Most paints are water based now, takes no time to dry these days....
42 minutes ago, TiTAN said:
When did you stop being all for men hugging in fields? I thought that was your 4th favourite thing to do?
Was till he ran outa lube... i think hes still soar and chaffed from last time
11 hours ago, TiTAN said:
I thought it had to do with letting the paint finish hardening before you start cutting into it with polishes as it's still technically "Soft" for a while after its dry.
Think of paint like skin, kind of. When a car gets freshly painted, or when you buy a new car, the paints generally still in a stage of de-gassing, where all of the gasses from the paint are slowly releasing. If you start covering it in polish/wax,  you clog the "pores" on the paint and get imperfections.
I've always been taught not to wash a car for 3-6 months after a paint job, although some paint shops have developed baking techniques to get the gasses out faster.
Ovens a pretty technical these days, my mates blow dries the paint inbetween coats then bakes it a different heat settings over a set period of time.
  • Like 2
On 9/21/2017 at 12:22 PM, Stinky Rooster said:
I would rather douse my genitals in hot sauce before dragging them through broken glass and razor blades, than drive a magna
Actually, I might do that anyway
results to be posted
  • Like 1
So technical. I was thinking if you just went really really fast the air would dry it out?
  • Like 2
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
