Elle to fix the control arms any cheaper you might have to go aftermarket.
Its actually a pretty old dodgy trick from manufacturers for aaaages. Even Ford did a similar thing, by cold riveting the lower ball joints to the arms, then only listing a part number for the complete lower arm - not just the ball joint.
Price about 10 years ago was $600+ per side for the arm from ford
or $35 for a ball joint, complete with bolts to replace the rivets...
  • Like 3
Same thing with bmws..... lol
  • Like 2
Here comes the rooster. I reckon dale is on the money.
  • Like 1
You think alike with dave , he said that before but guess the qualified mechanics should knows better lol no offense! [emoji23]
Yep I agree wouldn't touch your beast with a barge pole. Trolley jack scissor jacks and ramps in my car port. Would look hilarious;-)
  • Like 1
Don’t get me wrong , I won’t be happy to spend $1700 for the bushes but Nissan’s has design it specifically and I doubt after market bushes would fit in nicely ?
There maybe other way round it I don’t know ? Bushes are made from rubber, Nolathane , urethane or softer metal alloy and these bushes may been inserted during the manufacture of the control arm and not slip in and out of the assembly.
So either $1700 or pay for 2nd hand on eBay
Wait for Hanky to get back then sort it out with him it doesn’t sound super urgent
  • Like 2
Ill see if she can Tuesday when I have a day off. She might need a hand with questions as Sanae has no idea about cars.
I’d go aftermarket personally, but not the cheap cheap stuff. It’s not like you track the car and punish it through corners. Some aftermarket is as good as genuine and for the price I’d be a tight ass
If you can recommend any good aftermarket not cheap cheap stuff then , that would be great , any helps would be good :)
And Apparently I need to be a bit more aggressive with the car [emoji594]- hence one of the reasons it’s clunking.
Nite boys and thank you !
  • Like 1
Wow 1700bucks for stock pay the same n get fully adjustable made by high end after market company TOP SECRET.
https://www.nengun.com/top-secret/front-upper-arm-for-r35
Nice ! Thanks Mark , ill have a read and wait for Lochy :)
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
