My neighbour told me today that a white skyline pulled up in my driveway and was trying to get into my garage. This will be the third time someone's tried to steal my car in a year. Geeeeeze.
He wrote down the rego though.
  • Like 3
What is the rego? Everyone could keep a look out for that S.O.B.
  • Like 1
I've got to get it off of my neighbor when I next see him.
Scumbags
  • Like 1
2 hours ago, Beyond Blue R33 said:
7 hours ago, TiTAN said:
who would have thought that your neck just wasn't made to do that sort of thing.
Will be totally hairless after the back fusion opp. Coughing up rooster feathers.:-P
More than one way to skin a chicken
Damn my neck hurts
turns out spending a quiet evening licking bourbon bbq sauce off ones own nipples can have unforseen consequences [emoji20]
You would do it regularly enough that it’s probably not the source of your pain
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
