IMG_2227.thumb.jpg.6ffb113aec7b9a95669074f759c650a1.jpgIMG_2286.thumb.jpg.fed3c3425a6ef6b4041817ff45a91208.jpgIMG_2284.thumb.jpg.5275d12b4b0d77f9002fafe6f230819b.jpgIMG_2282.thumb.jpg.30d3c68bef6802152a8556eae3bf1200.jpg
Eye candy for you boys !
Bought my spare parts for $250 AUD !
Back home Josh wants $1700 , Nissan’s $2200 and I paid 26k Yen ! So how much is that in AUD [emoji23]IMG_2274.thumb.jpg.217186a957d4d861c9910139fbfb6d51.jpg
So jelly your in Japan [emoji627]
  • Like 1
Wanna come and swap dave’s place ? Hahahahah I think we Might have to cut the Holiday short as Dave are not Feeling well , his nose Bleeding none stop Since we arrived ( cauterize )
We Catching up with few friends today , to take him to the hospital.
Wanna come and swap dave’s place ? Hahahahah I think we Might have to cut the Holiday shorter as Dave are not Feeling well , his nose Bleeding none stop Since we arrived ( cauterize )
Bugger hope he gets better soon!
  • Like 1
my xmas bonus was being asked to come back on the 2nd instead of the 8th........
ahh the life of the scumbag mercenary contractor, how I have missed you.
Doc has laid down the law that I cant get back on the bike till march, so I'm now getting full on planning for some mods, looking for opinions.on direction
flat track / rat racer
01.jpg&key=72f68c476db4e391d7a695be159d6aaf4b03c9121ce37f7ae802c9ece5a0ba6a
street scrambler
a7d552e1562733cbd548e9a76627ad83.jpg&key=ecc28356e4160e961950450d6f8bc0e5ff73227f6055a2f8f411ff9a434824ff
or super motard
a87da3efdde383267a7c21b157470137.jpg&key=c449d6a03ae32ce1bed76d04d44ba42c2f796e9e6cca5edaa02516c688fea7c9
thoughts?
The weather is nice today would be my current thought. My one before that was how much I was enjoying my sausage rolls for lunch.
Jam a couple tampons up there [emoji12]
  • Like 3
Bummer Dave. That sucks.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
