50 minutes ago, turboedsloth said:
As are the black fresh water lobsters
are you coming on to me? because its working....
keen AF to get my hands on marron or crabs, due to not being able to hunt this season :(
I can put some in the freezer for you in if want? we are also going up Perth way on a sunday in the next 2 weeks apparently.
Went out last night, was murky as all buggery. Waiting for this rain to farkkk off before i go out again
  • Like 1
ken oath I would!!!! Also keen to catch up if you are coming up. Sunday WT lunch maybe?
I has a recipe for chilli lime and coriander crabcakes that brings all da boyz to mah yard.
42 minutes ago, turboedsloth said:
Sounds like a date.
I can't do crabs. But marron, hhhhhhhhhnnnnnnnnnnggggggggggggggggggg
ooooh jeebuz. You turn up here with marron I cant guarantee I wont wrap my legs around your face. Its literally been years :blush:
Hahahahahahahahah [emoji23] sounds like me & Dave ! We both bad with phones , gotta stop that tho
I usually only check the weather and Sau once or twice a day on holidays.
Delete Facebook, and you will thank me in a month when you realize how much spare time you have
  • Like 1
I can’t really delete Facebook, photos and business page all there [emoji24][emoji24]
Sunburn- sunscreen
Best sleep ever in our van...the beers prob help
Dirt- sometimes depending on location
Food- wife cooks as well camping as at home but menu choices are reduced
Scenery- sensational
thats some pretty flash welding there dude. Reckon I might hit you up soon for a foreigner [emoji14]
Thanks dale. MIG Welding is just welding, once the geometric pattern development is done I've already lost interest. Parallel, radial line and triangulation is the fun part for me :-) we finally have a bender arriving soon so. Exhaust manifold off, machined, sand blasted and painted with all new studs. Dual cai's, Ali coolant/dual motor washer bottle, pod filter box. Got bad hot air stacking under the bonnet. Would like to do Ali but might be stainless. Due to free bits from work. You know on top of the 50hrs I put in this week. Haven't used the turbo timer because intercooler but you can hear the manifold pinging under cool down. Don't want to go with lagging or blankets because it traps the heat in bad? Any thoughts?
Marc at C-Red reckon timers are pointless unless your racing, turbo blanket could be cool!
  • Like 1
Yeah my bro reconds the same. Switch it off while it's hot so the oil feed maintains pressure around the bearings. Dave said use it for now on Cool down because the manifold is warped and ticks bad for ages on cool down. Won't matter when it's fixed I suppose. Turbo/manifold blankets/lagging are a trade off because they hold the heat in which makes for less exhaust efficiency due to increased exhaust/turbo temps. Will do dual cai's. One to the original air box position, with the back open towards the turbo and one across the front of the engine toward the exhaust manifold through the hole that isnt used from front facing plenum. Will put heat shielding guards over the manifold and turbo that will hopefully keep the heat down to be blown out by cai's to avoid the stacking issue?
Have an industrial precision EGT sensor In my Ute. it drops from 350C to 160-180 in 20 seconds or so of idle or decel. Giving it another 2 minutes of idle time only gets it down to 150C so why bother.
Just back off for the last few seconds of driving and shut it straight down. Not being under load at the end the turbo will stop spinning relatively quick and thermal siphoning will help keep turbo coolish anyway.
Turbo timers are made to piss off the neighbours.
  • Like 2
I had a timer on the stagea, never actually used it for pretty much the reasons stated,
Also, I dont think heat retaining is an issue in turbos etc. its more the moisture the lagging traps, and how that leads to massive corrosion. Seen blokes do this to motorbike exhausts and they go paper thin within a year.
  • Like 1
most likely too busy chatting up 2nd hand military equipment dealers to bother with the likes of us
or, too busy trying to keep his dog from drowning itself at every chance. Seriously, it wouldnt even drink from my dogs bowl, unless BOTH front feet were inside the water dish - and my dog has a 40lt water dish....
  • Like 1
I had a timer on my old car, was built into the alarm. My car ticked and cracked once it had shit down, i thought it haf something todo with the fact the turbo and mani were cast, the downpipe was stainless and nuts and bolts were mild
  • Like 1
oh lawd
turns out "bring your kids to work day" doesn't really work when you are counting on engineers telling them what they do, to be enough entertainment and stimulation for kids. My normally quiet office currently sounds like a day care centre that has been accidentally hosed down with red cordial and dexxies.....
damn breeders.......
  • Like 1
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
