yes it would have damaged the CAT beyond repair.
remove immediately and show us your flames
Opps mis print "use" not used
Was thinking of it as my full tank did not last long. 2 closed car run about 5 to 8 laps each. lost count left me 1/4 left n still wanted to go play :(
  • Like 1
A 4"x6" piece of flaming metalic melted substrate on the porches windscreen would have definitely slowed it down.
  • Like 1
I melted this 100cell 4" ceramic on 98ron. At 350whp. Replaced with 100cell 4" by 6" metallic. No probs so far. The entire substrate came loose, blocked the exhaust and she popped a intercooler hose, was scary, it was glowing that bad you could almost see through it when the police came to have a look. But that's another story. I got the oval as a free replacement. If your worried about the cat I would go the venom 3" to 5" steel substrate. They fully weld the substrate in and are a quality product. :-D DSC_0162_4.JPGDSC_0167_3(1).JPGDSC_0163_4(1)(1).JPGDSC_0167_3(1).JPGDSC_0182_1(1).JPG
  • Like 1
22 hours ago, pol1on1 said:
Got a question? Will it hurt if you used avgas 110 octane leaded fuel.
All i can think of is an unhappy cat
Everuthing would dislike the avgas! Epic fuel tho, just dont buy it from the stale rusty horrible tanks at barbs lol
4 hours ago, pol1on1 said:
So racing fuel WA is the only good place ?
Pretty much unless u can get a license to import vp 109 race fuel ? or happen to know someone who qorks for shell at the airports ?
  • Like 1
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
