Dale.
I'm doing an order from Troy's Meats if you want anything - https://www.facebook.com/troysmeats/posts/706363436366223
Getting Hank some lambs necks, come in packs of 2 and they're full necks, not the little cut up rosettes, so awesome to keep the doggo interested for a while ("soft" bone as well).
Cant see FB at work, so link is no good, but you reckon you could grab an extra 2 packs of the necks for me? I will get Blossom's opinion of the secret butcher first before I go buck wild. OK if I fix you up for them on Sunday?
I had Cape Grim for the first time a few weeks ago, and would def recommend. Pretty sure he stocks the grass fed stuff
On ‎7‎/‎17‎/‎2018 at 8:37 PM, pol1on1 said:
Yer oil dipstick popped out too much pressure in crankcase.
Not sure to why i had so much pressure to do that. But to fix the problem and do happy track dayz i think i need a catch can, larger sump, baffle kit for sump n cam cover, oil restrictor Maybe even a oil accumulator on top.
Then it might hit the track again but for now ill keep it straight drag pass.
Did loose about 4ltrs of oil from 6 hardly touching the dipstick that how known something went wrong as i was going up the shecane at 6k to 8k rpm i look down n noticed oil pressure at 2kgcm2..... at that point my car seat had me by the balls.
No knocking but at idle in gear lift the clutch put load on engine makes a small squeaking sound n crank pully has very slight movement . So thrust bearing has worn too much. :(
Not fun.  The root cause of it all is blowby.  Around Wanneroo RB's should be fine.  Before you chuck any bandaids on it check the compression.  Also as has been said check the remaining oil for go fast glitter.
  • Like 1
Yup
So, I learned a thing today
Turns out there is a sentence terminator called an Interobang, and its actually recognized by Websters as a valid way to end a sentence, and is usually to infer either a rhetorical question, or a question used as a statement.
Actual composition is a combination of the question mark and the exclamation mark.
Unicode for it is U+203D for any fellow word nuts that want to give it a crack
  • Like 1
11 minutes ago, Stinky Rooster said:
Yup
Cool
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
