11 hours ago, t_revz said:
Driving through cockburn always makes me Wellard
Thats even better than..."I would rather be Upper Swan than Innaloo"
On 7/17/2018 at 8:37 PM, pol1on1 said:
Yer oil dipstick popped out too much pressure in crankcase.
Not sure to why i had so much pressure to do that. But to fix the problem and do happy track dayz i think i need a catch can, larger sump, baffle kit for sump n cam cover, oil restrictor Maybe even a oil accumulator on top.
Then it might hit the track again but for now ill keep it straight drag pass.
Did loose about 4ltrs of oil from 6 hardly touching the dipstick that how known something went wrong as i was going up the shecane at 6k to 8k rpm i look down n noticed oil pressure at 2kgcm2..... at that point my car seat had me by the balls.
No knocking but at idle in gear lift the clutch put load on engine makes a small squeaking sound n crank pully has very slight movement . So thrust bearing has worn too much. :(
Sure it hasnt cracked a piston and uv had excessive blow by?
I bloody hope not but i think i might put a borescope on my to do list.
As for me day dreaming of a rebuild stroker kit money can buy a 2.8 or get a rb30 and same money buys a 3.2 or 3.4 [emoji57]
Now my biggest problem is finding time to wipe my own ass.
Got another baby 11mths apart
Happy dayz happy dayz [emoji6]
Mine cracked 4 ring lands and was not visible from above and spark plugs looked normal. The one piston that cracked from rings touching would barely be visible from above but the spark plug always looked oily
  • Like 1
30 is not same money. So much small shit has to be changed for the extra height you never think about. As someone who has done it, the torque is awesome, the initial install is far more involved than just bolting it in and Then you have the rego issues.
The 2.8 is less of a headache, it's still a 26 as far as rego care and everything that unbolted just bolts back up. If you have the time/money and want the 3.2/3.4 then yes, it's awesome but don't expect it to be as quick to do or the same cost.
  • Like 1
35 minutes ago, Hank Scorpio said:
Man, I was smashed after yesterday. It was loooooong!
I am hearing that!
After you left yesterday, we got stuck into the cake, and before we knew it, finished the glaze just before 11pm
The dog still hadn't moved as of 6.30am this morning.
Yeah i was only thinking of the stroker kit only.
Isn't the height change the only problem was thinking that hypertune now make a low profile rocker covers.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
