Yeah i was only thinking of the stroker kit only.
Isn't the height change the only problem was thinking that hypertune now make a low profile rocker covers.
All your intake and exhaust needs to be modified for the extra height, intake may interfere with the brake booster etc
  • Like 1
ok so new turbo has arrived, looking at injectors and fuel pump on the injectors side of things any one know what i can get in bosch brand that will drop in to factory fuel rail? or should i replace that also? (for a rb25 neo) so many different infos on the interwebs now so confused
  • Like 2
I used these folk.
http://www.nzefi.com/products/fuel-system/fuel-system-injectors/vehicle-specific-injector-kits/
  • Like 1
yeah i saw those in my search as well as the kit from kudosmotorsport but was hoping someone would know the specifics (part number or anything) so can see if can get some better pricing? but thank you
3.0/3.2/3.4 would be the way to go for reliable power but its also the quickest was to empty ur life savings. Depends what how much hp u want...
Happy Belated birthday ! Hope you get spoilt rotten from the love one xx [emoji8]
P/s - I need more tv’s hahahaha my remotes suddenly just stop working
  • Thanks 1
Did you try replacing the batteries?
Hey all, we should do Nando’s soon!!
  • Like 2
Martin I did [emoji849] its an old tele and I bought the universal remote from JB hi Fi and it didnt work Either [emoji849]
Anyway Nandos is Perfect ! Lets do on Saturday ? Zod & Peter Keen x
  • Like 1
On 8/8/2018 at 5:32 PM, t_revz said:
Hey big daddy
How the screaming and shitty nappies going?
Oh and what about the baby?
She's going good, bub is going good also. We have figured out, that if we can settle her before 10ish she will sleep the night. Is already pretty good with workshop noises, makes noises and is super flirty with smiles and big eyes
On ‎14‎/‎08‎/‎2018 at 7:45 AM, turboedsloth said:
....... is super flirty with smiles and big eyes
that's freaking adorable
she is just like her Dad already!!!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
