11 minutes ago, t_revz said:
Deep fried onions?
I farken hope so.
Dale and I are setting up a man date at Side Door BBQ (although the wimminz will probably come and ruin the fun as well). Just saying, in case you need some BBQ chicken in yo lyfe...
I farken hope so.
That joint was grouse.
2 hours ago, t_revz said:
In the CBD with all the hoighty toighty types.
Too many buttoned shirts for my liking
orly?
my shirt is unbuttoned, and I am just up the west end....................
aaaand now my pants are off
