14 hours ago, TiTAN said:
Even your wife?
Mate, if you want to know true love, lock your dog and your mrs in a hot car for an hour.
When you open the car, which one is happy to see you?
  • Like 2
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
