16 hours ago, Stinky Rooster said:
WR's are good bikes,  but damn high maintenance to keep them running.
They also don't have a cush drive in the back wheel,  so if you ride them on the road it destroys the gearbox pretty quick,  so I would avoid a motard  version like the plague.
Had a crf which made metal when road riding. Just gotta keep it pinned!!
Hay Corey,  how many engines has the Kim been through?
Boss at my last job had one,  first ride he came on with me and some mates,  it ran out of compression and I had to tow it almost 30km with my busted arse xt600.
The engine rebuild came to slightly more $$ than he paid for the bike.
If you get a triumph,  look up Perth cafe racers on fb.  Awesome bunch of blokes to ride with
Had a fresh build before i purchased it thankfully. And i've put maybe 6hrs max on it. It's now for sale, wana buy it?
The boss has said i can only have 1 bike and 1 import that doesn't run.
Anyone looking to buy or know anyone looking to buy a Skyline? I'm drowning in medical bills at the moment so I have to part with the car.
Just swapped the engine last November to another RB25 with half the km's on it along with the nismo front bumper.
On 24/01/2020 at 9:07 PM, z00key said:
Friends I hope lol, have seen a couple of bikes down your way I was gunna say "Hey Trev" lol but figured that would be just rude
Not saying “hey Trev” is just rude
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
