3 hours ago, z00key said:
Not sure of the build up, could be from acid rain in japan?
Anyone up for a antilag supercruise in Collie later in the year?
basically $130 for almost all day unlimited use of the track. No drifting or standing burnouts but everything else is fine. next one is May but i can make it. hoping to make august or october
  • Like 1
1 minute ago, TiTAN said:
Have you tried using a razor on the stains/build up? Same way you would tackle bad build up on a glass shower door/partition. Needs to be fresh and sharp.
yep agreed.
thats how i clean the glass on my aquarium when its really dirty
Ok, New Windshield is on, It came pre-tinted which was nice. Looks much better than the last one.  and the Drivers Side door is fixed.
All but he charged me $603, and JapWreck charged me $125 for the window (which was the wrong window and I had to go back and get it swapped).
I played Tetris in my garage, moved a bunch of shit around etc... Now I can *just* barely fit the skyline in *if* I climb out through the passenger door
  • Like 2
Yeah the razor blade was 1 of the 1st things i tried with no change at all. Tried barmans friend, vinegar and baking soda, all sorts of Polish and all thats worked has been mothers water spot remover and a heavy duty buffer. As for track time i have never done it but could be keen.
  • Like 1
take care of it!!
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
