Thanks everyone. And[mention=24655]T_revz[/mention] did u pick up your thing all good? Happy to help out my brother in law
Brother in law [emoji15] oooih well f it :)
Speedy recovery Dean x
You didn't tell me you're going on surgery when I saw you last week , at least I can send you flowers [emoji259] xx
  • Like 1
Brother in law [emoji15] oooih well f it [emoji4]
Was soo busy that day. Yeah been having issues with my sholders with constant pins n needles in my fingers, and after 6 months of try this try that found out disk c5 and 6 are pushing into a nerve so needed surgery
Poor Kenny,
He is so busy offshore with the Navy and he really wants to buy my ute even though he can't access his money so he is willing to offer extra cash to secure the deal if I send it to him instead.
My heart goes out to him
  • Like 3
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
