  • 9 years later...
Thread revival, apologies!
I have a similar issue, strange noise that appears shortly after starting the car, fluctuates a bit with RPM... If you bring the revs up the noise sort of follows / trails behind and then settles if that makes sense?
Engine was built years ago with CAMTECH 268 Cams (9mm lift i believe) and the rest of the upgrade kit with the springs and retainers.
Can you upgrade the pulley itself, if the spring is too weak (same as on the VG30 Lumps) or is it pointing towards another issue?
Cheers!
  • 3 weeks later...
Got them measured (better late than never)
They seem to be the "wrong way around" IE Tighter on inlet and slacker on exhaust which I believe is actually the opposite to the norm on an RB? They're not perfect but am I right in saying they're not horrendous? I can't find the specs to suit the exact camtech cams anymore so using OEM and Other aftermarket specs they don't seem bad?
Put a video on to show. Using a stethoscope the noise doesn't seem to be focused around one area.
Worth noting the car has probably done 6000miles like this and it's never ever changed nor struggled to make power etc.
I'm a bit stumped!
Those numbers aren't terrible.
Another question, do you have an aluminium plenum? You could just be hearing the solid head a bit more because of that.
I know when I went from the stock intake manifold to an aftermarket intake manifold/plenum, everything became louder.
Injectors, lifters, became more audible.
11 hours ago, GTSBoy said:
Doesn't seem like it should cause them to be too noisy. Circa 0.4 is on the wider end of the range though. You can probably target more like 0.3 on the inlets.
Yeah that's exactly my thoughts but I'm far from an expert. Video didn't upload so will get it on YouTube and share the link. Thanks mate.
Yeah as above really they're not horrible numbers are they!
And it's on a greddy inlet. Has ID1050x that are quite noisy but tbh it did this on the older injectors. Lots of noise comes from the injector rail too.
56 minutes ago, Toff said:
Thanks for that, it actually sounds fine to me.
What oil weight are you running and what kind of oil pressure do you see around idle RPM and a bit over it?
I'm going to vote for considering going to the effort to close the lash down to the minimum. My bro-in-law got around to checking the clearances on the 3SGE in his Caldina. Was a bit fat all over. New shims at lowest allowable lash, and the car is remarkably better to drive. It appears that the increase in both total lift and duration that you get from doing this is worth a lot more than you might expect.
I have been having evil (and expensive and time consuming) thoughts about doing it to mine, and I don't even think I have a problem. Not that I'd know, though.
Yeah most people that have heard it said it was fine but it's always had me slightly worried.
Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60
You're probably right mate, best get ordering some shims!
Guessing Nissan is the best place for them?
I dunno. Maybe. There's a crowd here in Oz called Precision Shims that I'd probably look to first. Although NIssan might be surprisingly cheap enough.
Trouble with the process is you have to take all the existing shims out to measure them to know what you need to order.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
