  • 9 years later...
Thread revival, apologies!
I have a similar issue, strange noise that appears shortly after starting the car, fluctuates a bit with RPM... If you bring the revs up the noise sort of follows / trails behind and then settles if that makes sense?
Engine was built years ago with CAMTECH 268 Cams (9mm lift i believe) and the rest of the upgrade kit with the springs and retainers.
Can you upgrade the pulley itself, if the spring is too weak (same as on the VG30 Lumps) or is it pointing towards another issue?
Cheers!
  • 3 weeks later...
Got them measured (better late than never)
They seem to be the "wrong way around" IE Tighter on inlet and slacker on exhaust which I believe is actually the opposite to the norm on an RB? They're not perfect but am I right in saying they're not horrendous? I can't find the specs to suit the exact camtech cams anymore so using OEM and Other aftermarket specs they don't seem bad?
Put a video on to show. Using a stethoscope the noise doesn't seem to be focused around one area.
Worth noting the car has probably done 6000miles like this and it's never ever changed nor struggled to make power etc.
I'm a bit stumped!
Those numbers aren't terrible.
Another question, do you have an aluminium plenum? You could just be hearing the solid head a bit more because of that.
I know when I went from the stock intake manifold to an aftermarket intake manifold/plenum, everything became louder.
Injectors, lifters, became more audible.
11 hours ago, GTSBoy said:
Doesn't seem like it should cause them to be too noisy. Circa 0.4 is on the wider end of the range though. You can probably target more like 0.3 on the inlets.
Yeah that's exactly my thoughts but I'm far from an expert. Video didn't upload so will get it on YouTube and share the link. Thanks mate.
Yeah as above really they're not horrible numbers are they!
And it's on a greddy inlet. Has ID1050x that are quite noisy but tbh it did this on the older injectors. Lots of noise comes from the injector rail too.
56 minutes ago, Toff said:
Thanks for that, it actually sounds fine to me.
What oil weight are you running and what kind of oil pressure do you see around idle RPM and a bit over it?
I'm going to vote for considering going to the effort to close the lash down to the minimum. My bro-in-law got around to checking the clearances on the 3SGE in his Caldina. Was a bit fat all over. New shims at lowest allowable lash, and the car is remarkably better to drive. It appears that the increase in both total lift and duration that you get from doing this is worth a lot more than you might expect.
I have been having evil (and expensive and time consuming) thoughts about doing it to mine, and I don't even think I have a problem. Not that I'd know, though.
Yeah most people that have heard it said it was fine but it's always had me slightly worried.
Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60
You're probably right mate, best get ordering some shims!
Guessing Nissan is the best place for them?
I dunno. Maybe. There's a crowd here in Oz called Precision Shims that I'd probably look to first. Although NIssan might be surprisingly cheap enough.
Trouble with the process is you have to take all the existing shims out to measure them to know what you need to order.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
